This repository has been archived on 2023-02-09 . You can view files and clone it, but cannot push or open issues or pull requests.
12573e7158f61695bfe2316b08787c0bd0b0d0b8
Blender Benchmark Client
Run benchmarks, collect data!
CLI usage
- Ensure python3 is installed
- Copy the
config/farm.cfg.example
toconfig/farm.cfg
and edit if needed. If device_type is CPU, device_name will be ignored. - Run
benchmark/farm.py
- The results will be stored in the output_dir specified in
config/farm.cfg
Build for release
- Open Xcode, view account settings and ensure the presence of a macOS distribution certificate of type "Developer ID Application".
- Open Terminal, run
security find-identity
and ensure the presence of valid identity - Set env variable CODESIGN_IDENTITY to the valid identity
- Set env variable STORAGE_DIRECTORY to a directory where the bundling will happen
- Run
bundle/bundle.sh
The script will generate a .zip file containing the signed .dmg
Languages
JavaScript
70.9%
Python
23.8%
Shell
2.5%
CSS
2.3%
HTML
0.3%
Other
0.2%
