This repository has been archived on 2023-02-09 . You can view files and clone it, but cannot push or open issues or pull requests.
a04a10068af79001c0bf483653d6caf5f5650a4f
The issue is discussed in rBBB4726ee0c9c05
Blender Benchmark Client
Run benchmarks, collect data!
CLI usage
- Ensure python3 is installed
- Checkout the Blender scenes from
https://svn.blender.org/svnroot/bf-blender/trunk/lib/benchmarks/cycles/
into a
scenes
directory - Copy the
config/farm.cfg.example
toconfig/farm.cfg
and edit if needed. If device_type is CPU, device_name will be ignored. - Run
benchmark/farm.py
- The results will be stored in the output_dir specified in
config/farm.cfg
Build for release
- Open Xcode, view account settings and ensure the presence of a macOS distribution certificate of type "Developer ID Application".
- Open Terminal, run
security find-identity
and ensure the presence of valid identity - Set env variable CODESIGN_IDENTITY to the valid identity
- Set env variable STORAGE_DIRECTORY to a directory where the bundling will happen
- Run
bundle/bundle.sh
The script will generate a .zip file containing the signed .dmg
Languages
JavaScript
70.9%
Python
23.8%
Shell
2.5%
CSS
2.3%
HTML
0.3%
Other
0.2%
