This repository has been archived on 2023-02-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Francesco Siddi f254f806ce Update README.md
Add note about downloading Blender scenes from SVN.
2018-09-04 23:50:06 +02:00
2017-08-18 12:12:25 +02:00
2018-08-28 12:11:01 +02:00
Blender Benchmark Client
Run benchmarks, collect data!
CLI usage
  • Ensure python3 is installed
  • Checkout the Blender scenes from https://svn.blender.org/svnroot/bf-blender/trunk/lib/benchmarks/cycles/ into a scenes directory
  • Copy the config/farm.cfg.example to config/farm.cfg and edit if needed. If device_type is CPU, device_name will be ignored.
  • Run benchmark/farm.py
  • The results will be stored in the output_dir specified in config/farm.cfg
Build for release
  • Open Xcode, view account settings and ensure the presence of a macOS distribution certificate of type "Developer ID Application".
  • Open Terminal, run security find-identity and ensure the presence of valid identity
  • Set env variable CODESIGN_IDENTITY to the valid identity
  • Set env variable STORAGE_DIRECTORY to a directory where the bundling will happen
  • Run bundle/bundle.sh
The script will generate a .zip file containing the signed .dmg
S
Blender Benchmark Bundle
Readme 2.4 MiB
Languages
JavaScript 70.9%
Python 23.8%
Shell 2.5%
CSS 2.3%
HTML 0.3%
Other 0.2%
