Making the blender_cloud.pillar and blender_cloud.cache modules usable without Blender required some moving of the code, from __init__.py to blender.py. CacheControl requires the lockfile package, which increases the number of bundled wheel files to 3. Those are now managed by blender_cloud.wheels.load_wheels(). The wheels are only loaded if the Python installation doesn't yet contain the required packages. This allows development with virtualenv-installed packages, debugging in the IDE, etc.
Blender Cloud addon
Installation requires the Pillar SDK
to be installed. It can either be installed regularly somewhere on
the Python PATH, or be stored as a wheel file
at blender_cloud/pillar_sdk-*.whl
Assumptions
- Cache is user-global, stored in an OS-specific location, and can be removed/recreated. This
document refers to that location as
$CACHE
, and is typically a directory like$HOME/.cache/blender/blender_cloud
. Also see T47684. This directory should not be tied to the version of Blender -- malformed/invalid caches should just be ignored or removed. - At the moment, versioning of files is limited to re-syncing to get the latest versions. More extensive versioning falls under the umbrella of "asset management" and is out of scope of this addon.
- Users can download texture nodes. Such a download may result in multiple files on the local filesystem (think of one texture node containing diffuse, bump and specular maps).
Caching
Caching of HTTP GET requests is performed by CacheControl.
- Cache is stored in
$CACHE/blender_cloud_http/
; by using the file backend, we ensure cache persistence across Blender runs. This does require thelockfile
package to be installed or bundled. - The code should be made cache-aware and use the Requests-Cache
CachedSession
sessions. This allows for more granular control over where in the code cache is (not) used.
Downloaded thumbnails are cached (by us) in
$CACHE/thumbnails/node_uuid/filename
.- Use a non-cached HTTP GET to download these (using session.cache_disabled()).
- HTTP headers are stored as JSON key/value pairs in
$CACHE/thumbnails/node_uuid/filename.headers
. - Use the ETag and If-Modified-Since headers to prevent unnecessary re-downloading.
- Check Content-Length header against actual file size to detect partially-downloaded files that need re-downloading.
Downloaded files (such as textures) are handled in the same way as thumbnails (described above), but have their metadata stored somewhere else (described below).
Filesystem Layout
Top-level texture directory, referred to as
$TEXTURES
in this document, can be configured per Blender scene. It defaults to a global addon preference, which in turns defaults to//textures
Texture files are stored in
$TEXTURES/{project_name}/{node_name}/{node_name}/.../{file_variant}-{file_name}
.file_variant
is "col" for colour/diffuse textures, "nor" for normal/bump textures, etc. -
Metadata is stored in
$TEXTURES/.blender_cloud
, with the following subdirectories:projects/{project_uuid}.json
containing the project document from Pillarnodes/{node_uuid}.json
containing the node document from Pillarfiles/{file_uuid}.json
containing the file document from Pillarindex.sqlite
containing a mapping from{project_name}/{node_name}/{node_name}/...
to the UUID of the last-named path component (project, node, or file). This allows us to map the path of a filesystem path to its Pillar document.
