This repository has been archived on 2023-10-03. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Blender Cloud addon
Installation requires the Pillar SDK to be installed. It can either be installed regularly somewhere on the Python PATH, or be stored as a wheel file at blender_cloud/wheels/pillar_sdk-*.whl.
Assumptions
  • Cache is user-global, stored in an OS-specific location, and can be removed/recreated. This document refers to that location as $CACHE, and is typically a directory like $HOME/.cache/blender/blender_cloud. Also see T47684. This directory should not be tied to the version of Blender -- malformed/invalid caches should just be ignored or removed.
  • At the moment, versioning of files is limited to re-syncing to get the latest versions. More extensive versioning falls under the umbrella of "asset management" and is out of scope of this addon.
  • Users can download texture nodes. Such a download may result in multiple files on the local filesystem (think of one texture node containing diffuse, bump and specular maps).
Caching
  • Caching of HTTP GET requests is performed by CacheControl.
    • Cache is stored in $CACHE/blender_cloud_http/; by using the file backend, we ensure cache persistence across Blender runs. This does require the lockfile package to be installed or bundled.
    • The code should be made cache-aware and use the Requests-Cache CachedSession sessions. This allows for more granular control over where in the code cache is (not) used.
  • Downloaded thumbnails are cached (by us) in $CACHE/thumbnails/{node_uuid}/{filename}.
    • Use a non-cached HTTP GET to download these (using session.cache_disabled()).
    • HTTP headers are stored as JSON key/value pairs in $CACHE/thumbnails/{node_uuid}/{filename}.headers.
    • Use the ETag and If-Modified-Since headers to prevent unnecessary re-downloading.
    • Check Content-Length header against actual file size to detect partially-downloaded files that need re-downloading.
  • Downloaded files (such as textures) are handled in the same way as thumbnails (described above), but have their metadata stored somewhere else (described below).
Filesystem Layout
  • Top-level texture directory, referred to as $TEXTURES in this document, can be configured per Blender scene. It defaults to a global addon preference, which in turns defaults to //textures.
  • Texture files are stored in $TEXTURES/{project_name}/{node_name}/{node_name}/.../{file_variant}-{file_name}. {file_variant} is "col" for colour/diffuse textures, "nor" for normal/bump textures, etc.
  • Metadata is stored in $TEXTURES/.blender_cloud, with the following subdirectories:
    • files/{file_uuid}.json containing the file document from Pillar
    • files/{file_uuid}.headers containing a subset of the HTTP headers received while downloading the file
In the future we might add:
  • projects/{project_uuid}.json containing the project document from Pillar
  • nodes/{node_uuid}.json containing the node document from Pillar
  • index.sqlite containing a mapping from {project_name}/{node_name}/{node_name}/... to the UUID of the last-named path component (project, node, or file). This allows us to map the path of a filesystem path to its Pillar document.
S
This repository contains the Blender Cloud add-on. Since there is nobody available to work on it, it has been archived. If you want to help out as developer on this project, reach out via https://blender.chat/channel/blender-studio-website-support
Readme 1 MiB
Languages
Python 99.3%
Shell 0.7%
