This repository has been archived on 2023-10-03. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Blender Cloud addon
  • Using the Blender ID addon to authenticate against Blender ID
  • Using the Pillar SDK to browse the Blender Cloud texture library from within Blender.
  • Using Python's asyncio module to provide asynchronous execution of Python code in Blender.
Browsing texture folders
Browsing textures
Browsing textures
Installation
Installation requires the Pillar SDK to be installed. It can either be installed regularly somewhere on the Python PATH, or be stored as a wheel file at blender_cloud/wheels/pillar_sdk-*.whl.
Installation also requires wheels for CacheControl and lockfile to be placed in blender_cloud/wheels, or installed somewhere where Blender can find them.
The above requirements can be downloaded and built automatically by running the build-dependency-wheels.sh script. Only tested on Ubuntu Linux 14.04.
The addon requires HTTPS connections, and thus is dependent on D1845. You can do either of these:
  • Build Blender yourself
  • Get a recent copy from the buildbot
  • Copy certificate authority certificate PEM file to blender/2.77/python/lib/python3.5/site-packages/requests/cacert.pem. You can use the same file from your local requests installation, or use /etc/ssl/certs/ca-certificates.crt.
As a final step, install and log in with the Blender ID addon.
Running the addon
After installing the Blender Cloud addon, log in with the Blender ID (in the addon preferences). Then activate the Blender Cloud addon, and press Ctrl+Alt+Shift+A to activate it (yes, this needs work). Downloaded textures are loaded into image datablocks. The download location can be configured using the bpy.context.scene.blender_cloud_dir property (no GUI yet).
Motivation for asyncio
  1. Bundled with Python and supported by new syntax, most notably the await and async def statements.
  2. Allows for clear "handover points", where one task can be suspended and another can be run in its place. This provides for a much more deterministic execution flow than possible with multi-threading.
  3. Support for calling callbacks in the same thread that runs the event loop. This allows for elegant parallel execution of tasks in different threads, while keeping the interface with Blender single-threaded.
  4. Support for wrapping non-asyncio, blocking functionality (that is, the asynchronous world supports the synchronous world).
  5. Support for calling async def methods in a synchronous way (that is, the synchronous world supports the asynchronous world).
  6. No tight integration with Blender, making it possible to test asynchronous Python modules without running Blender.
The asyncio event loop
The event loop is the central execution device provided by asyncio. By design it blocks the thread, either forever or until a given task is finished. It is intended to run on the main thread; running on a background thread would break motivation 3 described above. For integration with Blender this default behaviour is unwanted, which is solved in the blender_cloud.async_loop module as follows:
  1. ensure_async_loop() starts AsyncLoopModalOperator.
  2. AsyncLoopModalOperator registers a timer, and performs a single iteration of the event loop on each timer tick. As only a single iteration is performed per timer tick, this only blocks for a very short time -- sockets and file descriptors are inspected to see whether a reading task can continue without blocking.
  3. The modal operator stops automatically when all tasks are done.
To start an asynchronous task and be notified when it is done, use the following. This uses the Blender-specific async_loop module.
import asyncio
async def some_async_func():
    return 1 + 1
def done_callback(task):
import asyncio
    return 1 + 1
print('Task result:', res)
Assumptions
  • Cache is user-global, stored in an OS-specific location, and can be removed/recreated. This document refers to that location as $CACHE, and is typically a directory like $HOME/.cache/blender/blender_cloud. Also see T47684. This directory should not be tied to the version of Blender -- malformed/invalid caches should just be ignored or removed.
  • At the moment, versioning of files is limited to re-syncing to get the latest versions. More extensive versioning falls under the umbrella of "asset management" and is out of scope of this addon.
  • Users can download texture nodes. Such a download may result in multiple files on the local filesystem (think of one texture node containing diffuse, bump and specular maps).
Caching
  • Caching of HTTP GET requests is performed by CacheControl.
    • Cache is stored in $CACHE/{username}/blender_cloud_http/; by using the file backend, we ensure cache persistence across Blender runs. This does require the lockfile package to be installed or bundled.
    • The code is cache-aware and uses the CacheControl-managed session object. This allows for more granular control over where in the code cache is (not) used.
    • Uncached HTTP requests user another session object to allow connection pooling.
  • Downloaded thumbnails are cached (by us) in $CACHE/thumbnails/{node_uuid}/{filename}.
    • Use a non-cached HTTP GET to download these.
    • A subset of HTTP headers are stored as JSON key/value pairs in $CACHE/thumbnails/{node_uuid}/{filename}.headers.
    • Use the ETag and If-Modified-Since headers to prevent unnecessary re-downloading.
    • Check Content-Length header against actual file size to detect partially-downloaded files that need re-downloading.
    • A file download is only attempted once per Blender session.
  • Downloaded files (such as textures) are handled in the same way as thumbnails (described above), but have their metadata stored somewhere else (described below).
Filesystem Layout
  • Top-level texture directory, referred to as $TEXTURES in this document, can be configured per Blender scene. It defaults to a global addon preference, which in turns defaults to //textures.
  • Texture files are stored in $TEXTURES/{project_name}/{node_name}/{node_name}/.../{file_variant}-{file_name}. {file_variant} is "col" for colour/diffuse textures, "nor" for normal/bump textures, etc.
  • Metadata is stored in $TEXTURES/.blender_cloud, with the following subdirectories:
    • files/{file_uuid}.json containing the file document from Pillar
    • files/{file_uuid}.headers containing a subset of the HTTP headers received while downloading the file
In the future we might add:
  • projects/{project_uuid}.json containing the project document from Pillar
  • nodes/{node_uuid}.json containing the node document from Pillar
  • index.sqlite containing a mapping from {project_name}/{node_name}/{node_name}/... to the UUID of the last-named path component (project, node, or file). This allows us to map the path of a filesystem path to its Pillar document.
This repository contains the Blender Cloud add-on. Since there is nobody available to work on it, it has been archived. If you want to help out as developer on this project, reach out via https://blender.chat/channel/blender-studio-website-support
Readme 1 MiB
Languages
Python 99.3%
Shell 0.7%
