This happened in Blender commit rBb2159b94bcd6c4e30c47b9970601e6f2ca2a0750
Blender Cloud addon
- Using the Blender ID addon to authenticate against Blender ID
- Using the Pillar SDK to browse the Blender Cloud texture library from within Blender.
- Using Python's asyncio module to provide asynchronous execution of Python code in Blender.
Browsing texture folders
{F299744}
Browsing textures
{F299745}
Installing the addon
- If you don't have one already, sign up for an account at the Blender ID site.
- If you had a previous version of the addon installed, deactivate it and restart Blender.
- Install and log in with the Blender ID addon.
- Install the Blender Cloud addon in Blender (User Preferences →
Addons → Install from file...) by pointing it to
blender_cloud*.addon.zip. - Enable the addon in User Preferences → Addons → System.
Running the addon
After installing the Blender Cloud addon, press Ctrl+Alt+Shift+A to activate it (yes, this needs work). Downloaded textures are loaded into image datablocks. The download location can be configured in the addon preferences.
Building an installable ZIP file
To build a ZIP file that can be installed by Blender, run
python setup.py bdist. This creates a ZIP file in the dist
directory. This command requires Git to be installed and available
from the CLI as git.
The addon requires:
- The Pillar Python SDK
- CacheControl
- lockfile, as this is a dependency of CacheControl.
These dependencies should either be installed somewhere where Blender
can find them, or be bundled as wheel files in blender_cloud/wheels.
The python setup.py bdist command gathers the dependencies and bundles
them as wheel files.
Motivation for asyncio
- Bundled with Python and supported by new syntax, most notably the
awaitandasync defstatements. - Allows for clear "handover points", where one task can be suspended and another can be run in its place. This provides for a much more deterministic execution flow than possible with multi-threading.
- Support for calling callbacks in the same thread that runs the event loop. This allows for elegant parallel execution of tasks in different threads, while keeping the interface with Blender single-threaded.
- Support for wrapping non-asyncio, blocking functionality (that is, the asynchronous world supports the synchronous world).
async defmethods in a synchronous way (that is, the synchronous world supports the asynchronous world). - No tight integration with Blender, making it possible to test asynchronous Python modules without running Blender.
The asyncio event loop
The event loop
is the central execution device provided by asyncio. By design it blocks
the thread, either forever or until a given task is finished. It is
intended to run on the main thread; running on a background
thread would break motivation 3 described above. For integration with
Blender this default behaviour is unwanted, which is solved in the
blender_cloud.async_loop module as follows:
ensure_async_loop()startsAsyncLoopModalOperator.AsyncLoopModalOperatorregisters a timer, and performs a single iteration of the event loop on each timer tick. As only a single iteration is performed per timer tick, this only blocks for a very short time -- sockets and file descriptors are inspected to see whether a reading task can continue without blocking.- The modal operator stops automatically when all tasks are done.
Recommended workflow
To start an asynchronous task and be notified when it is done, use the
following. This uses the Blender-specific async_loop module.
lang=python,name=async_example.py
import asyncio
async def some_async_func():
return 1 + 1
def done_callback(task):
lang=python,name=blocking_example.py
import asyncio
return 1 + 1
print('Task result:', res)
Assumptions
- Cache is user-global, stored in an OS-specific location, and can be removed/recreated. This
document refers to that location as
$CACHE, and is typically a directory like$HOME/.cache/blender/blender_cloud. Also see T47684. This directory should not be tied to the version of Blender -- malformed/invalid caches should just be ignored or removed. - At the moment, versioning of files is limited to re-syncing to get the latest versions. More extensive versioning falls under the umbrella of "asset management" and is out of scope of this addon.
- Users can download texture nodes. Such a download may result in multiple files on the local filesystem (think of one texture node containing diffuse, bump and specular maps).
Caching
Caching of HTTP GET requests is performed by CacheControl.
- Cache is stored in
$CACHE/{username}/blender_cloud_http/; by using the file backend, we ensure cache persistence across Blender runs. This does require thelockfilepackage to be installed or bundled. - The code is cache-aware and uses the CacheControl-managed session object. This allows for more granular control over where in the code cache is (not) used.
- Uncached HTTP requests user another session object to allow connection pooling.
Downloaded thumbnails are cached (by us) in
$CACHE/thumbnails/{node_uuid}/{filename}.- Use a non-cached HTTP GET to download these.
- A subset of HTTP headers are stored as JSON key/value pairs in
$CACHE/thumbnails/{node_uuid}/{filename}.headers. - Use the ETag and If-Modified-Since headers to prevent unnecessary re-downloading.
- Check Content-Length header against actual file size to detect partially-downloaded files that need re-downloading.
- A file download is only attempted once per Blender session.
Downloaded files (such as textures) are handled in the same way as thumbnails (described above), but have their metadata stored somewhere else (described below).
Filesystem Layout
Top-level texture directory, referred to as
$TEXTURESin this document, can be configured per Blender scene. It defaults to a global addon preference, which in turns defaults to//textures. -
Texture files are stored in
$TEXTURES/{project_name}/{node_name}/{node_name}/.../{file_variant}-{file_name}.{file_variant}is "col" for colour/diffuse textures, "nor" for normal/bump textures, etc. -
Metadata is stored in
$TEXTURES/.blender_cloud, with the following subdirectories:files/{file_uuid}.jsoncontaining the file document from Pillarfiles/{file_uuid}.headerscontaining a subset of the HTTP headers received while downloading the file
In the future we might add:
projects/{project_uuid}.jsoncontaining the project document from Pillarnodes/{node_uuid}.jsoncontaining the node document from Pillarindex.sqlitecontaining a mapping from{project_name}/{node_name}/{node_name}/...to the UUID of the last-named path component (project, node, or file). This allows us to map the path of a filesystem path to its Pillar document.
