0259c5e0ec7e3b66c9624f22d6d1782975af871d
This is needed for the copy button on file asset uploading. Rather than including it on all pages that could feature the file uploader it's now loaded globally.
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
After these commands, run deploy.sh
to build the static files and deploy
those too (see below).
All revisions to deploy to production should be on the production
branches of all the relevant
repositories.
Make sure you have these aliases in the [alias]
section of your ~/.gitconfig
ff = "merge --ff-only"
cd $projectdir
git status
git stash # if you still have local stuff.
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
# Push the production branch.
git push
workon blender-cloud # activate your virtualenv
cd $projectdir/deploy
./2docker.sh
./build-all.sh # or ./build-quick.sh
./2server.sh servername
To deploy another branch than production
, do export DEPLOY_BRANCH=otherbranch
before starting
the above commands.
Languages
Pug
51%
Python
33.9%
Sass
6.3%
Shell
5.4%
JavaScript
1.6%
Other
1.8%
