Sybren A. Stüvel 0a9f0ebddb Roles '{flamenco,attract}-user' are now linked to 'subscriber'
All users who get 'subscriber' role automatically get 'flamenco-user' and
'attract-user', and when 'subscriber' is revoked, so are
'{flamenco,attract}-user'.
2017-07-11 12:40:13 +02:00
2017-07-07 12:03:18 +02:00
2017-03-10 15:36:55 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
