12f1afa57f969da5e5947a66491616a4984b6309
Blender Cloud
Quick setup
Set up a node with these commands. Note that that script is already outdated...
#!/usr/bin/env bash
mkdir -p /data/git
mkdir -p /data/storage
mkdir -p /data/config
mkdir -p /data/certs
sudo apt-get update
sudo apt-get -y install python-pip
pip install docker-compose
cd /data/git
git clone git://git.blender.org/pillar-server.git pillar
First of all, add those aliases to the [alias]
section of your ~/.gitconfig
ff = "merge --ff-only"
cd $projectdir
git status
git stash # if you still have local stuff.
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
git pp # pp = "Push to Production"
Now follow the above receipe on the Blender Cloud project as well.
Contrary to the subprojects, git pp
will actually perform the deploy
for real.
Now you can press [ENTER]
in the Pillar and Attract terminals that
were still waiting for it.
Languages
Pug
51%
Python
33.9%
Sass
6.3%
Shell
5.4%
JavaScript
1.6%
Other
1.8%
