Sybren A. Stüvel 14d77da47a store.blender.org → EXTERNAL_SUBSCRIPTIONS_MANAGEMENT_SERVER
I've only done this on the billing page, because there it's important
for debugging purposes to know which URL was actually checked to obtain
the subscription expiry information.
2018-01-25 14:06:13 +01:00
2018-01-12 12:33:48 +01:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
