Tobias Johansson 22bd1a1a04 Added celery task for resuming archiving flamenco jobs that got stuck in status "archiving".
Jobs are considered stuck if they are in status "archiving" and hasn't been updated in a day.
2018-09-19 14:02:28 +02:00
2018-09-19 11:34:22 +02:00
2018-06-22 15:39:24 +02:00
2018-09-14 01:19:45 +02:00
2017-03-10 15:36:55 +01:00
2018-09-14 13:12:07 +02:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Development setup
Jumpstart Blender Cloud development with this simple guide.
System setup
Blender Cloud relies on a number of services in order to run. Check out the Pillar system setup to set this up.
Add cloud.local to the /etc/hosts file on localhost. This is a development convention.
Check out the code
Go to the local development directory and check out the following repositories, next to each other.
cd /home/guest/Developer
git clone git://git.blender.org/pillar.git
git clone git://git.blender.org/pillar-svnman.git
Initial setup and configuration
Create a virtualenv for the project and install the requirements:
cd blender-cloud
mkvirtualenv blender-cloud -p python3.6
pip install -r requirements-dev.txt
Build assets and templates for all Blender Cloud dependencies using Gulp.
./gulp all
Make a copy of the config_local example, which will be further edited as the application is configured.
cp config_local.example.py config_local.py
Setup the database with the initial collections and the admin user.
./manage.py setup setup_db your_email
The command will return the following message:
Created project <project_id> for user <user_id>
Copy the value of <project_id> and assign it as value for MAIN_PROJECT_ID.
Run the application:
./manage.py runserver
Development
When ready to commit, change the remotes to work over SSH. For example:
git remote set-url origin git@git.blender.org:blender-cloud.git
For more information, check out this guide.
All revisions to deploy to production should be on the production branches of all the relevant repositories.
Make sure you have these aliases in the [alias] section of your ~/.gitconfig:
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
# Push the production branch.
git push
workon blender-cloud  # activate your virtualenv
cd $projectdir/deploy
./2docker.sh
./build-all.sh  # or ./build-quick.sh
./2server.sh servername
To deploy another branch than production, do export DEPLOY_BRANCH=otherbranch before starting the above commands.
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
