Sybren A. Stüvel 54e9aca16f CLI reconcile_subscribers uses do_badger & re-grants the subscriber role
This ensures that subscriber-linked roles like flamenco-user are synced
along with the subscriber status, and that Algolia picks up on those
changes as well.
2017-07-11 14:29:14 +02:00
2017-07-07 12:03:18 +02:00
2017-03-10 15:36:55 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
