Sybren A. Stüvel 5a3a7a3883 LetsEncrypt fixes
- Changed virtual host weight for the letsencrypt docker so that it is
  higher than any other weight
- Copy the renewal script to the server (previously it was available
  to the host at /data/git/blender-cloud/…, but no longer.
2018-02-02 12:39:07 +01:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2018-02-02 12:20:00 +01:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
All revisions to deploy to production should be on the production branches of all the relevant repositories.
Make sure you have these aliases in the [alias] section of your ~/.gitconfig:
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
# Push the production branch.
git push
workon blender-cloud  # activate your virtualenv
cd $projectdir/deploy
./2docker.sh
cd $projectdir/docker
./full_rebuild.sh  # or one of the other build scripts, if you know what you're doing.
docker push armadillica/blender_cloud:latest
./2server.sh servername
To deploy another branch than production, do export DEPLOY_BRANCH=otherbranch before starting the above commands.
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
