Sybren A. Stüvel 5d26e3940e Bugsnag app revision: use timestamp instead of Git hash
This turns the 'revision' we send to Bugsnag into an incremental number
that denotes the current time. This is more indicative of the application
version than the git revision of the Blender Cloud repository, as the
latter doesn't include any changes in the other repositories.
2017-10-17 12:32:15 +02:00
2017-07-16 00:05:35 +02:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
