6b56df9e9ccf34156811b43aa9c1136ca87c5e4c
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
After these commands, run deploy.sh
to build the static files and deploy
those too (see below).
All revisions to deploy to production should be on the production
branches of all the relevant
repositories.
Make sure you have these aliases in the [alias]
section of your ~/.gitconfig
ff = "merge --ff-only"
cd $projectdir
git status
git stash # if you still have local stuff.
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
# Push the production branch.
git push
workon blender-cloud # activate your virtualenv
cd $projectdir/deploy
./2docker.sh
cd $projectdir/docker
./full_rebuild.sh # or one of the other build scripts, if you know what you're doing.
docker push armadillica/blender_cloud:latest
./2server.sh servername
To deploy another branch than production
, do export DEPLOY_BRANCH=otherbranch
before starting
the above commands.
Languages
Pug
51%
Python
33.9%
Sass
6.3%
Shell
5.4%
JavaScript
1.6%
Other
1.8%
