Sybren A. Stüvel 71a1a69f16 Updated paths for XSendFilePath
Now that we use egg links, and not symlinks, to install our packages,
we can use the actual paths.
2017-03-08 13:02:36 +01:00
2016-10-10 17:30:12 +02:00
2017-03-07 13:59:49 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
git clone git://git.blender.org/pillar.git -b py36
git clone git://git.blender.org/attract.git -b py36
git clone git://git.blender.org/flamenco.git -b py36
git clone git://git.blender.org/blender-cloud.git -b py36
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
