Sybren A. Stüvel 7ba1c55609 Biling page: moved user classification logic from template → view code
This is the kind of stuff that's much easier expressed in Python than in
the template code.
API calls removed:
  - fetching the user isn't necessary, since we have
    pillar.auth.current_user anyway.
  - a call for each group the user is member of, since we only used it to
    check whether the user has demo access anyway.
2018-01-25 14:06:13 +01:00
2018-01-12 12:33:48 +01:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
