Sybren A. Stüvel 8e6fc604e3 Build custom images for ElasticSearch & Kibana
We can then remove X-Pack and control ElasticSearch's memory usage.
This also gives us the opportunity to let Kibana do its optimization when
we build the image, rather than every time the container is recreated.
2017-09-21 11:28:16 +02:00
2017-09-19 13:45:48 +02:00
2017-07-16 00:05:35 +02:00
2017-07-13 18:26:54 +02:00
2017-08-30 15:06:09 +02:00
2017-03-10 15:36:55 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
