So far it's just a standalone docker container, as there is no publicly accessible Kibana container yet. To use, just SSH-tunnel port 9200.
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
After these commands, run deploy.sh
to build the static files and deploy
those too (see below).
First of all, add those aliases to the [alias]
section of your ~/.gitconfig
ff = "merge --ff-only"
cd $projectdir
git status
git stash # if you still have local stuff.
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
git pp # pp = "Push to Production"
Now follow the above receipe on the Blender Cloud project as well.
Contrary to the subprojects, git pp
will actually perform the deploy
for real.
Now you can press [ENTER]
in the Pillar, Attract, and Flamenco terminals
that were still waiting for it.
To update dependencies that need compiling, you need the 2_build
docker
container. To rebuild the lot, run docker/build.sh
- run
docker/build.sh
docker push armadillica/blender_cloud
On the production machine:
docker pull armadillica/blender_cloud
docker-compose up -d
(from the/data/git/blender-cloud/docker
directory)
