Sybren A. Stüvel 94ef616593 Placing code + assets directly into Docker image
This radically changes the way we deploy to the production server, as a
Git checkout is no longer required there. All the necessary files are
now inside the docker image. As a result, /data/git should no longer be
mounted as a Docker volume.
- Renamed docker/build.sh → docker/full_rebuild.sh
  This makes it clearer that it performs a full rebuild of the Docker images.
- Full rebuilds should be done on a regular basis to pull in Ubuntu
  security updates.
- Removed rsync_ui.sh, we no longer need it. Other projects can also
  remove their rsync_ui.sh.
- Moved deploy.sh → deploy/2docker.sh and added deploy/2server.sh
2018-02-02 12:01:17 +01:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
