Sybren A. Stüvel a2c24375e5 Webhooks: smarter way to find the user the webhook applies to.
We now also match on Blender ID (through the 'auth' section of the user
document), so that even when we have missed an email change we can still
apply the changes from the webhook.
2017-12-20 12:22:51 +01:00
2017-12-19 10:51:59 +01:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
