2016-11-06 18:58:51 +01:00
2016-10-10 17:30:12 +02:00
2016-08-30 13:51:44 +02:00
2016-08-10 18:27:27 +02:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
Set up a node with these commands. Note that that script is already outdated...
#!/usr/bin/env bash
mkdir -p /data/git
mkdir -p /data/storage
mkdir -p /data/config
mkdir -p /data/certs
sudo apt-get update
sudo apt-get -y install python-pip
pip install docker-compose
cd /data/git
git clone git://git.blender.org/pillar-server.git pillar
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
Now you can press [ENTER] in the Pillar and Attract terminals that were still waiting for it.
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
