Sybren A. Stüvel af14910fa9 WIP breaking stuff: updating docker image build process for Python 3.6
This requires a new way to pass requirements.txt files to Docker (since
they now link to each other), as well as building Python ourselves (since
even Ubuntu 16.10 doesn't have a decent Python 3.6).
This is just a WIP commit, will be fixed soon(ish).
2017-03-07 16:51:51 +01:00
2016-10-10 17:30:12 +02:00
2016-08-30 13:51:44 +02:00
2017-03-07 13:59:49 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
git clone git://git.blender.org/pillar.git -b py36
git clone git://git.blender.org/attract.git -b py36
git clone git://git.blender.org/flamenco.git -b py36
git clone git://git.blender.org/blender-cloud.git -b py36
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
