This will regularly run logrotate, preventing the build-up of log files of multiple gigabytes.
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
After these commands, run deploy.sh to build the static files and deploy
those too (see below).
ff = "merge --ff-only"
cd $projectdir
git status
git stash # if you still have local stuff.
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
git pp # pp = "Push to Production"
Now follow the above receipe on the Blender Cloud project as well.
Contrary to the subprojects, git pp will actually perform the deploy
for real.
Now you can press [ENTER] in the Pillar, Attract, and Flamenco terminals
that were still waiting for it.
To update dependencies that need compiling, you need the 2_build docker
container. To rebuild the lot, run docker/build.sh.
- run
docker/build.sh docker push armadillica/blender_cloud
On the production machine:
docker pull armadillica/blender_clouddocker-compose up -d(from the/data/git/blender-cloud/dockerdirectory)
