Pablo Vazquez c00121d71c Introducing main.sass stylesheet
Blender Cloud used main.css from Pillar
As we try to strip Blender Cloud-specific content from Pillar,
this commit brings three .sass files over to this repository.
There are still plenty of Blender Cloud classes all over Pillar,
they will be brought here over time.
2017-11-07 16:56:45 +01:00
2017-10-25 15:52:33 +02:00
2017-10-18 20:06:34 +02:00
2017-07-16 00:05:35 +02:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
