Sybren A. Stüvel d7e4995cfa WIP: more work on the docker structure, still not finished with 4_run
1_base: builds a base image, based on Ubuntu 16.10
2_buildpy: builds two images:
	2a: an image that can build Python 3.6
	2b: an image that contains the built Python 3.6 in /opt/python
3_buildwheels: builds an image to build wheel files, puts them in ../4_run
4_run: the production runtime image, which can't build anything and just runs.
2017-03-07 22:41:05 +01:00
2016-10-10 17:30:12 +02:00
2017-03-07 13:59:49 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
git clone git://git.blender.org/pillar.git -b py36
git clone git://git.blender.org/attract.git -b py36
git clone git://git.blender.org/flamenco.git -b py36
git clone git://git.blender.org/blender-cloud.git -b py36
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
