Blender Cloud
Quick setup
Set up a node with these commands. Note that that script is already outdated...
#!/usr/bin/env bash
mkdir -p /data/git
mkdir -p /data/storage
mkdir -p /data/config
mkdir -p /data/certs
sudo apt-get update
sudo apt-get -y install python-pip
pip install docker-compose
cd /data/git
git clone git://git.blender.org/pillar-server.git pillar
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
Now you can press [ENTER] in the Pillar and Attract terminals that were still waiting for it.
  1. run docker/build.sh
On the production machine:
Development setup
Here are some notes on how to get the whole Blender Cloud dev environment set up from scratch. First off, we agree to develop on bare metal and use Docker only for production.
Initial requirements:
  • Python 2.7
  • NPM
  • Blender ID server up and running (see blender-id for more)
Here are the steps:
  • Clone the fantastic 5 (pillar, pillar-python-sdk, attract, flamenco and blender-cloud)
  • Run npm install in pillar, attract and flamenco
  • Create config_local.py in blender-cloud
  • pip install -e . in every repo except blender-cloud
  • pip install -r requirements.txt in blender-cloud
  • setup_db
  • create_urler_account
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
