Sybren A. Stüvel de6cdbaf19 Fixed broken networking with new docker-compose.yml
- No more 'links', all dockers can reach each other by name
- Added 'depends_on', which handles startup sequence
- Allowed haproxy connection to the docker daemon socket
- Told haproxy explicitly which services to proxy. The 'docker:' prefix
  comes from the fact that the directory containing the docker-compose.yml
  file is called 'docker'.
2018-01-03 15:27:28 +01:00
2017-12-21 15:26:32 +01:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
