Sybren A. Stüvel f74e05229c Replace pillar-web with blender-cloud, and add HTTPS support
Other vhosts are already configured to use the 'blender-cloud' hostname,
and now the main one is too. It also adds HTTPS support, so that you can
test locally without having to set FORCE_SSL to false. This does require
you to create a TLS certificate in /data/certs/blender-cloud.pem, using:
openssl req -x509 -newkey rsa:4096 -keyout key.pem -out cert.pem -days 365 -nodes
cat key.pem cert.pem > blender-cloud.pem
rm key.pem cert.pem
2017-09-18 12:21:33 +02:00
2017-07-16 00:05:35 +02:00
2017-07-13 18:26:54 +02:00
2017-08-30 15:06:09 +02:00
2017-03-10 15:36:55 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
