Sybren A. Stüvel f7ce8d74a7 Implemented Blender ID webhook for user change notifications
Handles changes in:
 - roles
 - full name
 - email address
2017-12-01 19:06:16 +01:00
2017-11-30 15:45:40 +01:00
2017-11-14 16:25:03 +01:00
2017-07-13 18:26:54 +02:00
2017-03-10 15:36:55 +01:00
2017-11-14 16:09:29 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
