Sybren A. Stüvel fd700ca6d9 Inject current_user_is_subscriber into Jinja context
This variable is set to True iff the user has a subscriber/demo/admin role.
It's an attempt to get some of the Cloud subscription specific stuff out
of Pillar.
2017-06-14 16:26:29 +02:00
2017-03-10 15:36:55 +01:00
2016-08-30 13:52:28 +02:00
Blender Cloud
Quick setup
#!/usr/bin/env bash
sudo apt-get update
pip3 install docker-compose
cd /data/git
ff = "merge --ff-only"
cd $projectdir
git status
git pull
py.test
git push
git prod
git ff master
# Run tests again
py.test
  1. run docker/build.sh
On the production machine:
S
Blender Cloud
Readme 18 MiB
Languages
Pug 51%
Python 33.9%
Sass 6.3%
Shell 5.4%
JavaScript 1.6%
Other 1.8%
