This repository has been archived on 2023-02-07. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Sybren A. Stüvel d9b48a6e90 Migrate from custom oauth module to blender-id-oauth-client
The blender-id-oauth-client project was actually born from the My Data
oauth module, so the database layout is pretty similar. However, since
migration with the Django migration system is hard to get right (because
of ordering issues, we'd need the blender-id-oauth-client migrations to
be dependent on MyData migrations, which would break compatibility with any
other project), some manual intervention is necessary; see the README for
this.
2018-11-06 11:52:31 +01:00
2018-10-21 13:51:36 +02:00
2018-08-17 10:29:25 +02:00
2018-08-15 11:13:17 +02:00
2018-08-02 16:20:07 +02:00
2018-08-17 17:57:23 +02:00
2018-07-02 20:35:47 +02:00
Blender My Data
Portal to manage own benchmark results.
Requirements
Development setup
After cloning the Git repo, perform these steps to create a working dev server:
  • Make sure PostgreSQL is running and it has a mydata or similar database available
  • git submodule init and git submodule update
  • Copy mydata/settings.example.py to mydata/settings.py and adjust to your needs
  • Start your virtaulenv with pipenv shell
  • Install requirements with pipenv install
  • Run migrations ./manage.py migrate
  • Install frontend dependencies ./gulp
  • Run application ./manage.py runserver 8002
  • Configure Blender ID to have an OAuth Client with redirect URL http://mydata.local:8003/oauth/authorized
Try it out
  1. Submit an example benchmark with a valid Blender ID access_token $ sh examples/example.sh examples/benchmark.json your-blender-id-token You have to create the access_token manually at the moment since we don't have an authorized benchmark tool yet
  2. Open running application in Browser, login with Blender ID and manage your benchmarks.
Migrating from post-OAuth plugin era
In November 2018 we moved from using the oauth module in this project (which is now deleted, so don't bother searching for it except in the Git history) to using the Blender ID OAuth Client Django app. Since this was kinda hard to get correctly working with Django migrations, follow these steps instead:
pipenv run ./manage.py migrate
pipenv run ./manage.py migrate blender_id_oauth_client 0001
pipenv run ./manage.py dbshell
drop table blender_id_oauth_client_oauthtoken;
alter table oauth_oauthtoken rename to blender_id_oauth_client_oauthtoken;
alter sequence oauth_oauthtoken_id_seq rename to blender_id_oauth_client_oauthtoken_seq;
\q (or Ctrl+D)
This rolls back the blender_id_oauth_client migrations to a point in time where it used the same database model as mydata, then moves the mydata token table to the new Django app. After that, the migrations are re-run to split the tokens table into tokens + OAuth user mapping.
S
My Data
Readme 473 KiB
Languages
Python 64.4%
Pug 16.5%
Shell 8.9%
JavaScript 4.8%
Sass 2.8%
Other 2.6%
