This is the initial step for a change of name of the project, from brender to flamenco! All active stakeholders have been informed.
brender 2.0
Development repo for brender 2.0 (the original version 1.0 is here https://github.com/oenvoyage/brender). This is the Flask-based version, a new direction taken after getting some feedback from Sergey and Keir.
Developer installation
In order to install brender, we recommend to set up a Python virtual environment.
$ sudo easy_install virtualenv
On Linux this might work better:
$ sudo apt-get install python-virtualenv
Once you have virtualenv installed, just fire up a shell and create your own environment. You may want to create this folder inside of the brender folder:
$ cd brender
$ virtualenv venv
New python executable in venv/bin/python
Installing distribute............done.
Now, whenever you want to work on a project, you only have to activate the corresponding environment. On OS X and Linux, do the following:
$ . venv/bin/activate
Now you can just enter the following command to get Flask activated in your virtualenv:
Core dependencies
The project has been developped for python2.7.
On Unix systems, to install python dependencies, you may need to install python-dev package.
On OSX, in order to prevent some warnings, you should first run:
$ ARCHFLAGS=-Wno-error=unused-command-line-argument-hard-error-in-future
Then we just install all the packages required (run this on all systems)
$ pip install -r requirements.txt
Databases are managed by SQLite3.
Psutil is needed for gathering system usage/performance stats on the worker. Ideally psutil is needed only on the workers.
Congratulations, brender and its dependencies should be correctly installed and ready to run. As a final step we should add a couple of hostnames into the /etc/hosts file:
127.0.0.1 brender-server
127.0.0.1 brender-dashboard
127.0.0.1 brender-manager
Initialize brender
First you need to initialize the server and manager's databases:
$ cd server; ./manage.py db upgrade
$ cd manager; ./manage.py db upgrade
Running brender
It's pretty simple. Move into each node folder and run - in four different terminals:
$ ./manage.py runserver # will start the node (dashoard, server, manager or worker according to the current folder)
If you now visit http://brender-dashboard:8888 with your web browser you should see the dashboard!
It is also possible to configure the different applications. You may find a config.py.example, so you can rename
it to config.py and edit it before run the application.
Architecture
At the moment the content of the brender folder is quite messy due to refactoring. The important subfolders are:
servercontaining the server filesworkercontaining the worker files (render nodes)managercontaining the manager files (manage clusters)dashboardcontaining the dashboard (web interface to talk to the server)
This structure explains also the naming conventions adopted to distinguish the different parts of brender. Each folder contains an individual Flask application. Server, Manager and Worker exchange JSON formatted messages between each other via a Rest API. Dashboard connects to the Server only and accepts connections from clients (Browsers).
At the moment we have the following addresses:
- http://brender-server:9999
- http://localhost:5000
- http://brender-dashboard:8888
- http://brender-manager:7777
About the web interface
Frameworks and tools used by the interface are:
- jQuery
- Bootstrap
- DataTables
User and Developer documentation
Most of this document will be migrated into the docs folder, alongside with the user documentation.
The documentation is made with Sphinx and uses the readthedocs.org theme, so make sure you have it installed. Instructions are available here:
https://github.com/snide/sphinx_rtd_theme
The _build contains the locally compiled documentation, which does not need to be committed to the branch.
We are using sphinxcontrib-httpdomain for the API docs, so make sure you do:
pip install sphinxcontrib-httpdomain
