This repository has been archived on 2023-02-07. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Sybren A. Stüvel fc6e2b3b0b Latest Image system no longer writes to the static directory
This is necessary to run Flamenco Manager from a different directory than
the extracted tarball. Also an error opening the file is now shown in the
image, and some logging was improved.
2019-05-03 18:21:09 +02:00
2019-05-01 12:45:44 +02:00
2019-03-12 09:41:57 +01:00
2019-05-03 15:02:49 +02:00
Flamenco Manager
This is the Flamenco Manager implementation in Go.
Author: Sybren A. Stüvel sybren@blender.studio
Getting started
To run Flamenco Manager for the first time, follow these steps:
  1. Install ImageMagick and make sure that the convert command can be found on $PATH.
  2. If you don't want to use the bundled MongoDB server, download MongoDB Community Server and install it. This is recommended on Windows as it seems to improve stability.
  3. Download Flamenco Manager for your platform.
  4. Extract the downloaded file.
  5. Run ./flamenco-manager -setup (Linux/macOS) or flamenco-manager.exe -setup (Windows).
  6. Flamenco Manager will give you a list of URLs at which it can be reached. Open the URL that is reachable both for you and the workers.
  7. Link Flamenco Manager to Blender Cloud by following the steps in the web interface.
  8. Configure Flamenco Manager via the web interface. Update the variables and path replacement variables for your render farm; the blender variable should point to the Blender executable where it can be found on the workers, and similar for the ffmpeg variable. The path replacement variables allow you to set different paths for both Clients (like the Blender Cloud Add-on) and Workers, given their respective platforms.
  9. Once you have completed configuration, restart Flamenco Manager through the web interface. It will now run in normal (i.e. non-setup) mode.
Note that variables and path_replacement share a namespace -- variable names have to be unique, and cannot be used in both variables and path_replacement sections. If this happens, Flamenco Manager will log the offending name, and refuse to start.
Version numbers
Released versions of Flamenco Manager have a version number v{major}.{minor}, like v2.4, or v{major}.{minor}.{fix}, like v2.4.1.
Development versions have v{release}-{number}-{hash}, where number indicates the number of commits since the official version v{release}. The hash is the Git hash of the last commit. If the version number ends with -dirty it means that there were uncommitted changes when Flamenco Manager was built.
Advanced Configuration
Apart from the above web-based setup, you can configure advanced settings by editing flamenco-manager.yaml. For example, you can:
  • Manager secure communication (see the next section).
  • Set intervals for various periodic operations. See flamenco-manager-example.yaml for a description.
Intervals (like download_task_sleep) can be configured in seconds, minutes, or hours, by appending a suffix s, m, or h. Such a suffix must always be used.
HTTPS with custom TLS certificates or ACME/Let's Encrypt
To secure web traffic using HTTPS, we recommend using either Let's Encrypt or custom TLS certificates. Transport Layer Security (TLS) is the we-are-no-longer-living-in-the-90ies name for SSL.
Let's Encrypt can be used when the machine is publicly reachable and has a valid domain name. This is easy to set up, as it automatically requests & renews certificates:
  • Set acme_domain_name to the domain name of the machine.
  • Set both listen and listen_https to the ports Flamenco Manager should be listening to. By default these are :8080 and :8443.
  • Configure your firewall or user-facing proxy to forward ports 80 and 443 to respectively 8080 and 8443.
If you want to manage your own TLS certificates, set the path in the tlskey and tlscert configuration options. Then set listen_https to the appropriate port number.
CLI arguments
Flamenco Manager accepts the following CLI arguments:
  • -setup: Start in setup mode, which will enable the web-based setup on the /setup URL.
  • -debug: Enable debug-level logging
  • -quiet: Disable info-level logging (no-op if -debug is also given), so that only warnings and errors are logged.
  • -json: Log in JSON format, instead of plain text
  • -cleanslate: Start with a clean slate; erases all cached tasks from the local MongoDB, then exits Flamenco Manager. This can be run while another Flamenco Manager is running, but this scenario has not been well-tested yet.
  • -purgequeue: Erases all queued task updates from the local MongoDB, then exits Flamenco Manager. NOTE: this is a lossy operation, and it may erase important task updates. Only perform this when you know what you're doing.
Running as service via systemd (Linux-only)
  1. Build (see below) and configure Flamenco Manager.
  2. Edit flamenco-manager.service to update it for the installation location, then place the file in /etc/systemd/system.
  3. Run systemctl daemon-reload to pick up on the new/edited file.
  4. Run systemctl start flamenco-manager to start Flamenco Manager.
  5. Run systemctl enable flamenco-manager to ensure it starts at boot too.
Starting development
$FM denotes the directory containing a checkout of Flamenco Manager, that is, the absolute path of this flamenco-manager directory.
  1. Make sure you have MongoDB up and running (on localhost)
  2. Install Go 1.12 or newer and GNU Make.
  3. cd $FM
  4. Run make to download the dependencies and build Flamenco Manager. This will create an executable flamenco-manager in the current directory.
  • Run the unittests with make test
  • Configure Flamenco Manager by starting it in setup mode (./flamenco-manager -setup, see above).
  • Run the Manager with ./flamenco-manager.
Testing
To run all unit tests, run make test. To run a specific GoCheck test, run go test ./flamenco -v --run TestWithGocheck -check.f SchedulerTestSuite.TestVariableReplacement where the argument to --run determines which suite to run, and -check.f determines the exact test function of that suite. Once all tests have been moved over to use GoCheck, the --run parameter will probably not be needed any more.
Communication between Server and Manager
Flamenco Manager is responsible for initiating all communication between Server and Manager, since Manager should be able to run behind some firewall/router, without being reachable by Server.
In the text below, some_fields can refer to configuration file settings.
Fetching tasks
  1. When a Worker ask for a task, it is served a task in state queued or claimed-by-manager in the local task queue (MongoDB collection "flamenco_tasks"). In this case, Manager performs a conditional GET (based on etag) to Server at /api/flamenco/tasks/{task-id} to see if the task has been updated since queued. If this is so, the task is updated in the queue and the queue is re-examined.
  2. When the queue is empty, the manager fetches new tasks from the Server. This is also done when one clicks the "Kick task downloader" button in the dashboard.
Task updates and canceling running tasks
  1. Pushes happen as POST to "/api/flamenco/managers/{manager-id}/task-update-batch"
  2. Task updates queued by workers are pushed every task_update_push_max_interval, or when task_update_push_max_count updates are queued, whichever happens first.
  3. An empty list of task updates is pushed every cancel_task_fetch_max_interval, unless an actual push (as described above) already happened within that time.
  4. The response to a push contains the database IDs of the accepted task updates, as well as a list of task database IDs of tasks that should be canceled. If this list is non-empty, the tasks' statuses are updated accordingly.
Timeouts of active tasks
When a worker starts working on a task, that task moves to status "active". The worker then regularly calls /may-i-run/{task-id} to verify that it is still allowed to run that task. If this end-point is not called within active_task_timeout_interval_seconds seconds, it will go to status "failed". The default for this setting is 60 seconds, which is likely to be too short, so please configure it for your environment.
This timeout check will start running 5 minutes after the Manager has started up. This allows workers to let it know they are still alive, in case the manager was unreachable for longer than the timeout period. For now this startup delay is hard-coded.
Missing features / future work
In no particular order:
  • GZip compression on the pushes to Server. This is especially important for task updates, since they contain potentially very large log entries.
  • A way for Flamenco Server to get an overview of Workers, and set their status.
Building distributable packages
The distributable Flamenco Manager packages are built using GNU Make.
  1. Install GNU Make for your platform.
  2. Prepare the bundled MongoDB server files:
    • Download MongoDB for Linux (the "legacy" build), Windows (the "2008 and later without SSL" version), and MacOS (the version without SSL). Versions without SSL support are used because they're simpler and we listen on localhost anyway so SSL is not necessary.
    • Extract the files you downloaded (the Windows version may require msiextract from the msitools package if you're extracting on Linux).
    • Make sure the contents can be found in dist/mongodb-{linux-x86_64,osx-x86_64,windows}-version, so the Linux bin directory should be in dist/mongodb-{linux-x86_64,osx-x86_64,windows}-version/bin.
    • Remove everything from the bin directories except mongod (or mongod.exe for the Windows version).
  3. Run make package to create the distributable packages.
Worker Sleep Schedule
Each worker has a sleep schedule, which can be configured from the dashboard and behaves in the following way:
  • When the schedule is not active, it doesn't influence the worker at all.
  • When the schedule is active, the worker is requested to be active by default, unless the schedule allows it to sleep.
  • When the schedule has 'days of week' set to a non-empty string, the worker is only sent to sleep on those days. When 'days of week' is empty, the worker is allowed to sleep on every day. The 'days of week' should be a space-separated list of the first two letters of the days, like "mo tu we".
  • The worker is allowed to sleep between the schedule's start and end time. Those times default to respectively the start and end of the day.
S
Flamenco-manager
Readme 13 MiB
Languages
Go 52.7%
JavaScript 41%
HTML 3.5%
Python 1.3%
CSS 1.2%
Other 0.3%
