This requires Flamenco Server 2.2 or newer. Progressive render jobs generated by older versions of Flamenco Server are no longer supported.
Flamenco Worker
This is the Flamenco Worker implemented in Python 3.
Author: Sybren A. Stüvel sybren@blender.studio
Installation
- Make sure you have Flamenco Manager up and running.
- Install Blender and make sure the
blenderbinary is on$PATH. - Install FFmpeg and make sure the
ffmpegandffprobebinaries are on$PATH. If you only intend to run Flamenco Worker and not run any unit tests, you can skipffprobe. - Install Flamenco Worker in one of two ways:
- If you have a distributable zip file (see
Packaging for distribution) unzip it,
cdinto it, then run./flamenco-worker(orflamenco-worker.exeon Windows). - If you have a copy of the source files, run
pipenv installthen runflamenco-worker. This requires Python 3.7 or newer.
Upgrading
Upgrading from a previous version of Flamenco Worker is simple:
- Unpack the package you downloaded from flamenco.io.
- Copy the
flamenco-worker.cfgandflamenco-worker.dbfiles from your previous installation. - Start Flamenco Worker.
Configuration
Configuration is read from three locations:
- A hard-coded default in the Python source code.
flamenco-worker.cfgin the current working directory, i.e. the directory that your shell is in when you invoke theflamenco-workercommand.$HOME/.flamenco-worker.cfg; this file is optional.
The configuration files should be in INI format, as specified by the configparser documentation
Configuration contents:
All configuration keys should be placed in the [flamenco-worker] section of the
config files. At least take a look at:
manager_url: Flamenco Manager URL. Leave blank to auto-discover Flamenco Manager on your network using UPnP/SSDP.task_types: Space-separated list of task types this worker may execute.task_update_queue_db: filename of the SQLite3 database holding the queue of task updates to be sent to the Master.
These configuration keys are also required, but are created automatically in
$HOME/.flamenco-worker.cfg when they don't exist yet:
worker_id: ID of the worker, handed out by the Manager upon registration (see Registration below) and used for authentication with the Manager.worker_secret: Secret key of the worker, generated by the Worker and given to the Manager upon registration and authentication.
TODO
- Certain settings are currently only settable by editing constants in the Python source code. It might be nice to read them from the config file too, at some point.
Invocation
Install using pip3 install -e . for development, or python3 setup.py install for production.
This creates a command flamenco-worker, which can be run with --help to obtain
a list of possible CLI arguments.
Registration
If the configuration file does not contain both a worker_id and worker_secret, at startup
the worker will attempt to register itself at the Master.
Once registered via a POST to the manager's /register-worker endpoint, the worker_id and
worker_secret will be written to $HOME/.flamenco-worker.cfg
Task fetch & execution
- A task is obtained by the FlamencoWorker from the manager via a POST to its
/taskendpoint. If this fails (for example due to a connection error), the worker will retry every few seconds until a task fetch is succesful. - The task is given to a TaskRunner object.
- The TaskRunner object iterates over the commands and executes them.
- At any time, the FlamencoWorker can be called upon to register activities and log lines, and forward them to the Manager. These updates are queued in a SQLite3 database, such that task execution isn't interrupted when the Manager cannot be reached.
- A separate coroutine of TaskUpdateQueue fetches updates from the queue, and forwards them to
the Master, using a POST to its
/tasks/{task-id}/updateendpoint. TODO: the response to this endpoint may indicate a request to abort the currently running task. This should be implemented.
Shutdown
Pressing [CTRL]+[C] will cause a clean shutdown of the worker. If there is a task currently running,
it will be aborted without changing its status. Any pending task updates are sent to the Manager,
and then the Manager's /sign-off URL is POSTed to, to indicate a clean shutdown of the worker. Any
active task that is still assigned to the worker is given status "claimed-by-manager" so that it can
be re-activated by another worker.
Systemd integration
To run Flamenco Worker as a systemd-managed service, copy flamenco-worker.service to
/etc/systemd/system/flamenco-worker.service, then run systemctl daemon-reload.
After installation of this service, systemctl {start,stop,status,restart} flamenco-worker
commands can be used to manage it. To ensure that the Flamenco Worker starts at system boot,
use systemctl enable flamenco-worker.
Signals
Flamenco Worker responds to the following POSIX signals:
SIGINT,SIGTERM: performs a clean shutdown, as described in the Shutdown section above.SIGUSR1: logs the currently scheduled asyncio tasks.
First run pipenv install --dev to fetch developer dependencies. On Windows,
download the Microsoft Visual C++ 2010 Redistributable Package.
On Ubuntu/Debian, make sure you have the 'binutils' package installed.
Run mkdistfile.py to create a distributable archive (.zip on Windows, .tar.gz on Linux and
macOS) containing a runnable Flamenco Worker. This build doesn't require installing Python or any
dependencies, and can be directly run on a target machine of the same OS.
NOTE: pyinstaller must be run on each supported platform, to create files for that platform. It cannot cross-build.
