Flamenco Worker
This is the Flamenco Worker implemented in Python 3.
Author: Sybren A. Stüvel sybren@blender.studio
Installation
There are a few ways to install Flamenco Worker:
If you have a distributable zip file (see Packaging for distribution) unzip it, then run
pip install flamenco_worker-xxxx.whl -
If you have a copy of the source files, run
pip install -e .
Configuration
Configuration is read from three locations:
- A hard-coded default in the Python source code.
flamenco-worker.cfgin the current working directory.$HOME/.flamenco-worker.cfg.
When those files do not exist, they are skipped (i.e. this is not an error). They should be in INI format, as specified by the configparser documentation
Configuration contents:
All configuration keys should be placed in the [flamenco-worker] section of the
config files.
manager_url: Flamenco Manager URL.worker_id: ID of the worker, handed out by the Manager upon registration (see Registration below) and used for authentication with the Manager.worker_secret: Secret key of the worker, given to the Manager upon registration and authentication.job_types: Space-separated list of job types this worker may execute.task_update_queue_db: filename of the SQLite3 database holding the queue of task updates to be sent to the Master.
TODO
- Certain settings are currently only settable by editing constants in the Python source code. It might be nice to read them from the config file too, at some point.
- Update worker address in MongoDB when communicating with it.
Invocation
Install using pip install -e . for development, or setup.py install for production.
This creates a command flamenco-worker, which can be run with --help to obtain
a list of possible CLI arguments.
Registration
If the configuration file does not contain both a worker_id and worker_secret, at startup
the worker will attempt to register itself at the Master.
Once registered via a POST to the manager's /register-worker endpoint, the worker_id and
worker_secret will be written to $HOME/.flamenco-worker.cfg
Task fetch & execution
- A task is obtained by the FlamencoWorker from the manager via a POST to its
/taskendpoint. If this fails (for example due to a connection error), the worker will retry every few seconds until a task fetch is succesful. - The task is given to a TaskRunner object.
- The TaskRunner object iterates over the commands and executes them.
- At any time, the FlamencoWorker can be called upon to register activities and log lines, and forward them to the Manager. These updates are queued in a SQLite3 database, such that task execution isn't interrupted when the Manager cannot be reached.
- A separate coroutine of TaskUpdateQueue fetches updates from the queue, and forwards them to
the Master, using a POST to its
/tasks/{task-id}/updateendpoint. TODO: the response to this endpoint may indicate a request to abort the currently running task. This should be implemented.
Shutdown
Pressing [CTRL]+[C] will cause a clean shutdown of the worker.
If there is a task currently running, it will be aborted without changing its status. Any pending task updates are sent to the Manager, and then the Manager's /sign-off URL is
POSTed to, to indicate a clean shutdown of the worker. Any active task that is still
assigned to the worker is given status "claimed-by-manager" so that it can be re-activated
by another worker.
Systemd integration
To run Flamenco Worker as a systemd-managed service, copy flamenco-worker.service to
/etc/systemd/system/flamenco-worker.service, then run systemctl daemon-reload.
After installation of this service, systemctl {start,stop,status,restart} flamenco-worker
commands can be used to manage it. To ensure that the Flamenco Worker starts at system boot,
use systemctl enable flamenco-worker.
Signals
Flamenco Worker responds to the following POSIX signals:
SIGINT,SIGTERM: performs a clean shutdown, as described in the Shutdown section above.SIGUSR1: logs the currently scheduled asyncio tasks.
Run python setup.py zip to create a distributable zip file. It contains the Wheel,
example configuration file, this README.md, license information and system integration
files.
