This header is included with each request, so that the Manager can handle software version bookkeeping however it sees fit.
Flamenco Worker
This is the Flamenco Worker implemented in Python 3.
Configuration
Configuration is read from three locations:
- A hard-coded default in the Python source code.
flamenco-worker.cfgin the current working directory.$HOME/.flamenco-worker.cfg.
When those files do not exist, they are skipped (i.e. this is not an error). They should be in INI format, as specified by the configparser documentation
Configuration contents:
All configuration keys should be placed in the [flamenco-worker] section of the
config files.
manager_url: Flamenco Manager URL.worker_id: ID of the worker, handed out by the Manager upon registration (see Registration below) and used for authentication with the Manager.worker_secret: Secret key of the worker, given to the Manager upon registration and authentication.job_types: Space-separated list of job types this worker may execute.task_update_queue_db: filename of the SQLite3 database holding the queue of task updates to be sent to the Master.
TODO
- Certain settings are currently only settable by editing constants in the Python source code. It might be nice to read them from the config file too, at some point.
- Update worker address in MongoDB when communicating with it.
Invocation
Install using pip install -e . for development, or setup.py install for production.
This creates a command flamenco-worker, which can be run with --help to obtain
a list of possible CLI arguments.
Registration
If the configuration file does not contain both a worker_id and worker_secret, at startup
the worker will attempt to register itself at the Master.
Once registered via a POST to the manager's /register-worker endpoint, the worker_id and
worker_secret will be written to $HOME/.flamenco-worker.cfg
Task fetch & execution
- A task is obtained by the FlamencoWorker from the manager via a POST to its
/taskendpoint. If this fails (for example due to a connection error), the worker will retry every few seconds until a task fetch is succesful. - The task is given to a TaskRunner object.
- The TaskRunner object iterates over the commands and executes them.
- At any time, the FlamencoWorker can be called upon to register activities and log lines, and forward them to the Manager. These updates are queued in a SQLite3 database, such that task execution isn't interrupted when the Manager cannot be reached.
- A separate coroutine of TaskUpdateQueue fetches updates from the queue, and forwards them to
the Master, using a POST to its
/tasks/{task-id}/updateendpoint. TODO: the response to this endpoint may indicate a request to abort the currently running task. This should be implemented.
Shutdown
Pressing [CTRL]+[C] will cause a clean shutdown of the worker.
If there is a task currently running, it will be aborted without changing its status. Any pending task updates are sent to the Manager, and then the Manager's /sign-off URL is
POSTed to, to indicate a clean shutdown of the worker. Any active task that is still
assigned to the worker is given status "claimed-by-manager" so that it can be re-activated
by another worker.
Systemd integration
To run Flamenco Worker as a systemd-managed service, copy flamenco-worker.service to
/etc/systemd/system/flamenco-worker.service, then run systemctl daemon-reload.
After installation of this service, systemctl {start,stop,status,restart} flamenco-worker
commands can be used to manage it. To ensure that the Flamenco Worker starts at system boot,
use systemctl enable flamenco-worker.
Signals
Flamenco Worker responds to the following POSIX signals:
SIGINT,SIGTERM: performs a clean shutdown, as described in the Shutdown section above.SIGUSR1: logs the currently scheduled asyncio tasks.
