2e4c5b2663f09f66cea6eff21115034838ad9c45
Node.create_asset_from_file() is split such that the actual file upload is handled by File.upload_to_project(). This now also supports directly uploading from a file object, which could be an io.BytesIO() object to upload from RAM.
Pillar Python REST SDK
Integrate this module in your Python app to communicate with an Pillar server.
Caching
Requests-Cache can be used to cache HTTP requests. The Pillar Python REST SDK does not support it directly, but provides the means to plug in different session objects:
import requests_cache
import pillarsdk
req_sess = requests_cache.CachedSession(backend='sqlite',
cache_name='blender_cloud')
pillarsdk.Api.requests_session = req_sess
Any pillarsdk.Api instance will now use the cached session. To
temporary disable it, use:
api = pillarsdk.Api.Default(endpoint="https://your.endpoint")
with api.requests_session.cache_disabled():
node = pillarsdk.Node.find('1234')
Languages
Python
99.4%
Shell
0.6%
