Sybren A. Stüvel 49edc1e3ad Fix compatibility with Tox
This may require you to delete your `.tox` directory for a clean run.
2019-05-10 14:07:20 +02:00
2019-04-26 15:50:41 +02:00
2018-08-29 14:21:45 +02:00
2017-03-03 12:23:45 +01:00
2018-09-17 18:45:26 +02:00
2015-08-31 19:25:01 +02:00
Pillar Python REST SDK
Integrate this module in your Python app to communicate with a Pillar server.
Supports Python 3.5 and 3.6. Currently also supports Python 2.7, but support will be ending soon.
Caching
Requests-Cache can be used to cache HTTP requests. The Pillar Python REST SDK does not support it directly, but provides the means to plug in different session objects:
import requests_cache
import pillarsdk
req_sess = requests_cache.CachedSession(backend='sqlite',
                                        cache_name='blender_cloud')
pillarsdk.Api.requests_session = req_sess
Any pillarsdk.Api instance will now use the cached session. To temporary disable it, use:
api = pillarsdk.Api.Default(endpoint="https://your.endpoint")
with api.requests_session.cache_disabled():
    node = pillarsdk.Node.find('1234')
S
Pillar-python-sdk
Readme 225 KiB
Languages
Python 99.4%
Shell 0.6%
