.gitea
Gitea: use full URL for referencing pull requests
2023-03-07 13:24:58 +01:00 |
.github
Docs: change Git URLs to point projects.blender.org instead of git.blender.org
2023-02-07 14:46:01 +01:00 |
add_camera_rigs
Fix Add Camera Rigs after 4.0 API changes
2023-09-27 13:19:02 +02:00 |
add_curve_extra_objects
Extra objects: Fix TypeError when torus knot added
2023-08-01 13:41:10 +02:00 |
add_curve_sapling
Fix #104794: Handle blank lines in the sapling preset files
2023-08-02 20:53:51 +02:00 |
add_mesh_BoltFactory
Mesh: Update addons for auto smooth removal
2023-10-20 16:53:43 +02:00 |
add_mesh_discombobulator
Remove bl_options from menus which caused tests to fail
2023-09-07 17:50:38 +10:00 |
add_mesh_extra_objects
add_mesh_geodesic_domes
License headers: use SPDX-FileCopyrightText for all addons
2023-06-15 16:54:05 +10:00 |
amaranth
Support loading add-ons without an active key-config
2023-12-20 12:28:10 +11:00 |
animation_animall
Fix #105009: AnimAll: Error when inserting key on string attribute
2023-11-17 14:07:24 +01:00 |
ant_landscape
Merge branch 'blender-v3.6-release'
2023-06-19 21:48:14 -04:00 |
archimesh
Fix #104981: Archimesh: Remove usage of SHARP distribution on Glossy BSDF
2023-11-07 09:36:23 +01:00 |
blender_id
btrace
curve_tools
Curve tools: Calculate length on multiple curves
2023-08-16 23:12:05 +02:00 |
greasepencil_tools
hydra_storm
Hydra Storm: prepare for MaterialX export support
2023-09-07 19:11:48 +02:00 |
io_anim_bvh
Cleanup: autopep8 on io_anim_bvh
2023-08-09 17:56:56 +10:00 |
io_anim_nuke_chan
io_coat3D
Fix: Use correct displacement_method property
2023-12-04 19:12:10 +01:00 |
io_curve_svg
io_export_dxf
io_import_dxf
io_import_palette
io_mesh_atomic
Shaders: update for Principled BSDF changes
2023-09-25 19:29:00 +02:00 |
io_mesh_stl
io_mesh_uv_layout
Export UV Layout: fix property descriptions
2023-11-21 18:20:33 +01:00 |
io_scene_3ds
io_scene_3ds: Removed property decorate
2023-12-17 12:02:40 +01:00 |
io_scene_fbx
Fix #105045: Error importing FBX custom properties on placeholder PoseBones
2023-12-09 01:49:56 +00:00 |
io_scene_gltf2
glTF exporter: Fix exporting animation when gpu instancing is enabled
2023-12-11 11:06:55 +01:00 |
io_scene_x3d
Fix: Missing keyword for mesh sharpness angle argument
2023-10-24 09:35:39 +02:00 |
io_shape_mdd
magic_uv
Fix #104729. Added missing OperatorStrokeElement keywords.
2023-07-02 12:29:45 +02:00 |
materials_library_vx
materials_utils
Fix #93749: Material Utilities addon not working due to API changes
2023-12-17 14:09:41 +01:00 |
measureit
mesh_inset
mesh_snap_utilities_line
Fix #110601: Line Tool crashes when object has subdivision surface
2023-07-31 13:01:46 -03:00 |
mesh_tiny_cad
mesh_tissue
mesh_tools
node_wrangler
Fix #104941: Node Wrangler cannot use both bump and normal
2023-12-20 18:57:10 +01:00 |
object_carver
object_collection_manager
Collection Manager: Bump versions. #69577
2023-10-31 05:18:01 -04:00 |
object_fracture_cell
Fix: Update Cell Fracture for removal of old style context override
2023-07-19 21:40:03 +02:00 |
object_print3d_utils
object_scatter
pose_library
Pose Library: Tweak to the add-on description
2023-09-20 11:44:14 +02:00 |
power_sequencer
precision_drawing_tools
presets
Sun Position: remove presets
2023-11-16 14:33:15 +01:00 |
render_copy_settings
Copy Render Settings: Add support for Cycles, Eevee and Workbench settings.
2023-08-25 18:41:18 +02:00 |
render_povray
rigify
Fix #105075: Rigify fails to upgrade metarigs with unnamed layers.
2023-12-21 12:13:19 +02:00 |
space_view3d_brush_menus
space_view3d_math_vis
Math Vis Console - fixed errors drawing quaternions and eulers
2023-10-14 13:04:24 +02:00 |
space_view3d_pie_menus
space_view3d_spacebar_menu
space_view3d_stored_views
storypencil
sun_position
Sun Position: tweak translation
system_demo_mode
ui_translate
UI messages fixes/cleanups.
2023-11-20 12:20:40 +01:00 |
vdm_brush_baker
Fix #105028: Error when trying to create texture with VDM Brush Baker
2023-11-30 15:36:45 +01:00 |
viewport_vr_preview
.gitignore
add cycles folder to gitignore
2018-10-29 12:49:40 +01:00 |
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
camera_turnaround.py
copy_global_transform.py
curve_assign_shapekey.py
curve_simplify.py
depsgraph_debug.py
development_edit_operator.py
development_icon_get.py
development_iskeyfree.py
Is key Free: Adjust character width for East Asian languages
2023-09-08 13:25:56 +02:00 |
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
Cleanup: strip trailing space
2023-11-09 14:05:23 +11:00 |
io_import_images_as_planes.py
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py
Fix #105026: BSurfaces: 'ToolSettings' object has no attribute 'use_snap_project'
2023-11-25 10:11:45 -03:00 |
mesh_f2.py
mesh_looptools.py
node_arrange.py
node_presets.py
object_boolean_tools.py
object_color_rules.py
object_edit_linked.py
object_skinify.py
paint_palette.py
real_snow.py
render_freestyle_svg.py
render_ui_animation_render.py
space_clip_editor_refine_solution.py
space_view3d_3d_navigation.py
space_view3d_align_tools.py
space_view3d_copy_attributes.py
Copy Attributes: fix Copy Visual Scale
2023-10-17 16:32:29 +02:00 |
space_view3d_modifier_tools.py
system_blend_info.py
system_property_chart.py
