.gitea
Gitea: add merge message templates
2023-01-30 23:54:21 +01:00 |
.github
Docs: change Git URLs to point projects.blender.org instead of git.blender.org
2023-02-07 14:46:01 +01:00 |
add_camera_rigs
Create Camera Rigs: fix DoF bone for 2D rig
2022-09-21 15:38:16 +02:00 |
add_curve_extra_objects
D16656: Add Curve: Extra Objects - Add Curve Spiral Objects not conforming to 3D-Cursor Location
2022-12-03 17:36:19 +02:00 |
add_curve_sapling
Fix T101985: Willow preset in tree gen addon not usable
2022-11-29 09:21:16 +05:30 |
add_mesh_BoltFactory
Corrected resource leak when adding in EDIT mode
2022-02-14 17:55:45 +13:00 |
add_mesh_discombobulator
File headers: use SPDX license identifiers
2022-02-11 16:34:06 +11:00 |
add_mesh_extra_objects
Cleanup: fix typos
2022-10-14 19:52:42 +02:00 |
add_mesh_geodesic_domes
2022-02-14 14:47:00 +11:00 |
amaranth
Amaranth: Fix addon un-register function
2022-09-20 10:03:28 +02:00 |
animation_animall
AnimAll: fix translations
2022-08-29 00:20:47 +02:00 |
ant_landscape
Cleanup: fix typos
archimesh
Archimesh: Register Undo for some missing operators
2022-08-16 15:20:48 +02:00 |
blender_id
Official add-ons: fix printf-style format translation for i18n
2022-11-15 11:13:22 +01:00 |
btrace
Fix T98902: Btracer Particle Trace is broken
2022-07-05 11:18:38 +02:00 |
curve_tools
D16212: Curve Tools: Ensure nested paths in exported SVG look as expected. (Authored by Johan Althoff (teetow))
2022-10-23 01:00:28 +03:00 |
greasepencil_tools
Cleanup: trailing space
2023-01-31 15:47:58 +11:00 |
io_anim_bvh
io_anim_nuke_chan
Cleanup: remove <pep8 compliant> comment
2022-06-03 11:50:32 +10:00 |
io_coat3D
Cleanup: fix typos
io_curve_svg
io_export_dxf
io_import_dxf
io_import_palette
Fix 104401: Import .ase files with swatch groups
2023-02-13 10:45:14 +01:00 |
io_mesh_atomic
Atomic Blender: Get nodes with their types instead of names
2023-02-09 23:02:28 +01:00 |
io_mesh_ply
PLY: Fix T103203 export with UVs
2022-12-14 18:16:38 +03:00 |
io_mesh_stl
Cleanup: fix typos in blender addons
2022-08-09 19:24:13 +02:00 |
io_mesh_uv_layout
UV Layout: replace deprecated bgl module
2022-09-21 20:38:06 -03:00 |
io_scene_fbx
Cleanup: fix a few typos in UI messages
2023-02-09 00:03:06 +01:00 |
io_scene_gltf2
Merge branch 'blender-v3.5-release'
2023-02-16 17:18:35 +01:00 |
io_scene_obj
OBJ: mark Python IO legacy in the name too
2022-07-05 11:30:50 +03:00 |
io_scene_x3d
Fix T95455, T102384: Correct RGB color construction
2022-11-21 08:52:24 -03:00 |
io_shape_mdd
magic_uv
Magic UV: Get nodes with their types instead of names
2023-02-11 01:33:21 +01:00 |
materials_library_vx
Cleanup: fix source comment typos
2022-03-15 18:31:13 +01:00 |
materials_utils
Fix T104270: Error in materials_utils "unregister" function
2023-02-01 23:13:12 +11:00 |
measureit
Cleanup: fix typos
mesh_inset
Cleanup: fix typos
mesh_snap_utilities_line
Fix T103356: 'NoneType' object has no attribute 'is_valid'
2022-12-20 12:02:43 -03:00 |
mesh_tiny_cad
mesh_tissue
Tissue: Use vertex color functions instead of operators
2022-08-02 16:25:50 -05:00 |
mesh_tools
Cleanup: fix typos
node_wrangler
Node Wrangler: remove obsolete Geometry Nodes preview
2023-02-03 19:14:52 +01:00 |
object_carver
Carver: replace deprecated bgl module
2022-09-21 22:38:34 -03:00 |
object_collection_manager
Collection Manager: Fix "Add/Remove nested from selection". Task: T69577
2022-08-30 08:41:19 -04:00 |
object_fracture_cell
Cleanup: fix various typos
2022-06-30 17:21:18 +02:00 |
object_print3d_utils
Print 3D utils: make default exported file name translatable
2022-10-05 17:32:22 +02:00 |
object_scatter
Scatter Objects: replace deprecated bgl module
2022-07-28 12:29:35 -03:00 |
pose_library
pose_library: minor changes for shortcuts to show in menus
2023-01-11 19:30:26 +11:00 |
power_sequencer
precision_drawing_tools
Cleanup: fix typos
presets
UI: Update deep grey community theme
2022-05-30 09:07:59 +02:00 |
render_copy_settings
render_povray
rigify
Rigify: bump version.
2023-02-07 17:54:26 +02:00 |
space_view3d_brush_menus
space_view3d_brush_menus: Improve brush icon support.
2022-04-10 01:10:26 -04:00 |
space_view3d_math_vis
Math Vis: replace deprecated bgl module
2022-07-28 12:29:39 -03:00 |
space_view3d_pie_menus
Fix T98289: Asset Browser and Geometry Nodes in Pie menu
2022-11-09 17:28:28 -03:00 |
space_view3d_spacebar_menu
Spacebar Menu: remove old pose library from menu
2022-04-07 11:23:26 +02:00 |
space_view3d_stored_views
Stored Views: Fix error when Lock 'To 3D Cursor' is active
2022-05-18 12:56:25 +02:00 |
storypencil
Storypencil: Cleanup comments
2023-01-25 18:26:56 +01:00 |
sun_position
Fix #104407: Sun Position: shader error when enabling
2023-02-13 13:39:44 -03:00 |
system_demo_mode
ui_translate
viewport_vr_preview
.gitignore
add cycles folder to gitignore
2018-10-29 12:49:40 +01:00 |
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
2022-02-11 16:05:07 +11:00 |
camera_turnaround.py
copy_global_transform.py
Copy Global Transform: add documentation URL
2022-12-12 15:45:06 +01:00 |
curve_assign_shapekey.py
Curve Assign Shape Keys: replace deprecated bgl module
2022-07-21 11:03:42 -03:00 |
curve_simplify.py
depsgraph_debug.py
Depsgraph Debug: add an operator to generate an SVG and open in browser.
2022-06-29 20:07:20 +03:00 |
development_edit_operator.py
fix accidentally re-added license header
2022-06-13 23:03:01 +02:00 |
development_icon_get.py
Fix T101708: Bug when joining nodes with thick lines
2022-10-20 13:15:36 +02:00 |
development_iskeyfree.py
Cleanup: remove "Tweak" event type
2022-03-02 17:33:31 +11:00 |
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
io_import_images_as_planes.py
Fix T103359: Images as Planes: texture extension not applying
2022-12-23 11:51:26 -03:00 |
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py
Cleanup: fix typos
mesh_f2.py
mesh_looptools.py
Cleanup: fix typos
node_arrange.py
node_presets.py
Fix T90845: Add missing geometry node type
2022-02-17 17:35:30 +11:00 |
object_boolean_tools.py
Fix T98953: Typo in property name.
2022-06-17 11:33:32 +02:00 |
object_color_rules.py
Object Color Rules: fix object selection
2022-06-10 09:57:29 +02:00 |
object_edit_linked.py
object_skinify.py
paint_palette.py
real_snow.py
Real Snow material update
2022-06-08 15:35:40 +02:00 |
render_freestyle_svg.py
render_ui_animation_render.py
Fix T101239: UI Animation Render: Attribute error when running in background
2022-09-21 10:18:38 +02:00 |
space_clip_editor_refine_solution.py
Migrate to an updated motion tracking principal point property
2022-11-22 11:55:37 +01:00 |
space_view3d_3d_navigation.py
space_view3d_align_tools.py
Align Tools: allow undo for all operators and presets for advanced
2022-10-20 13:15:43 +02:00 |
space_view3d_copy_attributes.py
Fix #104036: Copy Attributes does not work on faces
2023-02-09 22:01:34 +01:00 |
space_view3d_modifier_tools.py
Fix T103455: Modifier tools add-on don't support GPencil modifiers
2022-12-26 12:32:00 +05:30 |
system_blend_info.py
system_property_chart.py
system_property_chart: support custom properties
2022-07-22 15:59:27 +10:00 |
