Add-ons bundled with Blender releases
Go to file
Sebastian Sille 808466d8d8 Export_3ds: Fixed key error in matrix calculation
A key error raises with 'selection only' option when selected object has an unselected parent
This is fixed now
Signed-off-by: Sebastian Sille <nrgsille@noreply.localhost>
2023-05-08 00:34:12 +02:00
.gitea
.github
add_camera_rigs
add_curve_extra_objects
add_curve_sapling
add_mesh_BoltFactory
add_mesh_discombobulator
add_mesh_extra_objects
add_mesh_geodesic_domes
amaranth
animation_animall Animall: update French translations 2023-04-14 01:55:10 +02:00
ant_landscape
archimesh
blender_id Cleanup: UI messages fixes and tweaks. 2023-04-17 11:41:34 +02:00
btrace
curve_tools
greasepencil_tools
io_anim_bvh Fix #104510: X3D & BVH import error with Python 3.11 2023-04-06 19:06:56 +10:00
io_anim_nuke_chan
io_coat3D
io_curve_svg
io_export_dxf
io_import_dxf Fix #104531: DXF importer zero division error 2023-04-18 20:12:13 +02:00
io_import_palette
io_mesh_atomic
io_mesh_ply Cleanup: Remove setting polygon loop total 2023-04-12 08:46:40 -04:00
io_mesh_stl
io_mesh_uv_layout io_mesh_uv_layout: speed up png export with OIIO (x7) 2023-04-13 20:25:42 +10:00
io_scene_3ds Export_3ds: Fixed key error in matrix calculation 2023-05-08 00:34:12 +02:00
io_scene_fbx Revert "FBX Export: Fix export of meshes with polygons in different order to loops" 2023-04-28 19:28:11 +02:00
io_scene_gltf2 io_scene_gltf2: quiet error running when context.space is None 2023-04-30 12:57:20 +10:00
io_scene_obj Cleanup: Remove setting polygon loop total 2023-04-12 08:46:40 -04:00
io_scene_x3d Cleanup: Remove setting polygon loop total 2023-04-12 08:46:40 -04:00
io_shape_mdd
magic_uv
materials_library_vx
materials_utils
measureit
mesh_inset
mesh_snap_utilities_line
mesh_tiny_cad
mesh_tissue
mesh_tools
node_wrangler Node Wrangler: Fix #104555, multiple operators using virtual sockets 2023-04-23 20:18:30 +02:00
object_carver
object_collection_manager
object_fracture_cell
object_print3d_utils
object_scatter Scatter Objects: Add documentation and tracker urls 2023-04-15 23:01:27 -04:00
pose_library
power_sequencer
precision_drawing_tools
presets Sun Position: capitalize preset names 2023-04-14 18:56:31 +02:00
render_copy_settings
render_povray Fix povray rendering metaballs with materials 2023-04-04 19:45:13 +10:00
rigify
space_view3d_brush_menus
space_view3d_math_vis
space_view3d_pie_menus
space_view3d_spacebar_menu
space_view3d_stored_views
storypencil
sun_position Sun Position: Cleanup: remove unused code 2023-04-14 20:43:49 +02:00
system_demo_mode
ui_translate Minor update to ui_translate addons to cleanup output. 2023-04-17 14:34:56 +02:00
viewport_vr_preview
.gitignore
add_curve_ivygen.py
animation_add_corrective_shape_key.py
bone_selection_sets.py
camera_turnaround.py
copy_global_transform.py Copy Global Transform: add tracker URL 2023-04-11 17:25:20 +02:00
curve_assign_shapekey.py
curve_simplify.py
depsgraph_debug.py
development_edit_operator.py
development_icon_get.py
development_iskeyfree.py
io_anim_camera.py
io_export_paper_model.py
io_export_pc2.py
io_import_BrushSet.py
io_import_images_as_planes.py
lighting_dynamic_sky.py
lighting_tri_lights.py
mesh_auto_mirror.py
mesh_bsurfaces.py
mesh_f2.py
mesh_looptools.py
node_arrange.py
node_presets.py
object_boolean_tools.py
object_color_rules.py
object_edit_linked.py
object_skinify.py
paint_palette.py
real_snow.py
render_freestyle_svg.py
render_ui_animation_render.py
space_clip_editor_refine_solution.py
space_view3d_3d_navigation.py
space_view3d_align_tools.py
space_view3d_copy_attributes.py
space_view3d_modifier_tools.py
system_blend_info.py
system_property_chart.py
