This repository has been archived on 2023-10-09. You can view files and clone it. You cannot open issues or pull requests or push a commit.
Ton Roosendaal f77bc7eb7d Quite a large one this time... but now we have:
Edges in Mesh
- adds automatic when you use creases. For other situations; call the
  void make_edges(Mesh *me) in mesh.c. Of course, once in editmode the
  edges are automatically recreated.
- in F9 buttons you can add/remove edges too
- both for Mesh and DisplistMesh, so it speeds up drawing quite some in
  wireframe
- render for edges can't work... edges have no material nor tface nor col..
  so here still the faces are rendered in wire
Creases in Subsurf
- based on the code by Chris McFarlen
- main changes is that now edges are used, saving quite some data in file
- use SHIFT+E in editmode to set edges-sharpness. values go from 0-1
- in F9 buttons you can set draw-crease mode. It draws now blended from
  wire color to edge-select color (as provided in Theme)
Known issue: setting sharpness on 1 cube (subdiv 2) gives weird results
with some values... Chris, can you check?
Further; code cleanups, changing 0 in NULL when needed, no warnings, etc etc
2004-07-08 20:38:27 +00:00
2004-05-27 08:05:55 +00:00
2004-06-04 03:04:56 +00:00
2003-09-08 12:13:54 +00:00
2004-07-03 17:28:15 +00:00
2002-11-15 06:57:59 +00:00
Welcome to the fun world of open-source.
For instructions on building and installing Blender, please see the file named
INSTALL.
---------------------.Blanguages and the .blender directory---------------------
The .blender directory holds various data files for Blender.
In the 2.28a release those are the .Blanguages file containing a list of
translations, the translations themselves and a default ttf font.
Blender checks for the presence of this directory in several locations:
	- the current directory
	- your home directory
	- On OSX, the blender bundle is also checked
	- On Windows, the installation dir is checked.
If you get a 'File ".Blanguages" not found' warning, try to copy the .blender
dir to one of these locations (your home directory being recommended).
-------------------------------------Links--------------------------------------
Getting Involved:
http://www.blender.org/docs/get_involved.html
Community:
http://www.blender3d.org/Community/
Main blender development site:
The Blender project homepage:
http://projects.blender.org/projects/bf-blender/
Documentation:
http://www.blender.org/modules.php?op=modload&name=documentation&file=index
Bug tracker:
http://projects.blender.org/tracker/?atid=125&group_id=9&func=browse
Feature request tracker:
http://projects.blender.org/tracker/?atid=128&group_id=9&func=browse
S
Archive of Blender with old branches
Readme 823 MiB
Languages
C 67.4%
C++ 23.4%
Python 6.1%
CMake 1.5%
GLSL 1.1%
Other 0.4%
